ISP Tuning in Verdin IMX8MP board
We are currently working on ISP tuning in Verding imx8mp development board with our own camera.
As per the documents from NXP I can understand there are 2 modules are involved in ISP.
  1. ISP-IMX
  2. ISP-VVCAM
For ISP tuning, we need to choose correct version of those 2 modules according the BSP which we are working.
Currently I am working with Toradex BSP 6.0.0, Kindly suggest me which Versions of ISP-IMX, ISP-VVCAM I should use for ISP tuning ?
For ISP tuning on the Verdin iMX8M Plus (imx8mp) development board using Toradex BSP 6.0.0, you will need to ensure compatibility with the specific versions of the ISP-IMX and ISP-VVCAM modules. However, the exact versions of these modules that are compatible with Toradex BSP 6.0.0 are not specified in the provided context.
To get the correct versions, I recommend the following steps:
  1. Check the Toradex BSP Release Notes: The release notes for BSP 6.0.0 should provide information on the versions of various components, including ISP-IMX and ISP-VVCAM, that are included or compatible with this BSP version.
  2. Consult NXP Documentation: Since the ISP modules are from NXP, their documentation should provide version compatibility information. Look for any specific notes on the versions of ISP-IMX and ISP-VVCAM that are recommended for use with the i.MX 8M Plus SoC.
  3. Contact Toradex Support: If the information is not readily available in the documentation, reaching out to Toradex technical support can provide you with the precise versions you need. They can offer guidance based on your specific BSP version and use case.
  4. Community and Forums: Sometimes, other developers might have faced similar issues. Checking forums and community discussions related to Toradex and NXP might provide insights or direct answers.
Without the exact version details in the provided context, these steps should help you identify the correct versions of ISP-IMX and ISP-VVCAM for your ISP tuning tasks.
BSP 6.0.0 doesn't build.
