I understand you’re looking to start a systemd service automatically to run your application updates on a Verdin iMX8MP module, and you’re interested in updating your application over Ethernet.
To address your first point, if your systemd service is not starting as expected, ensure the service file is correctly configured and enabled. A typical systemd service file for your application might look something like this:
[Unit]
Description=My Application Service
After=network.target
[Service]
Type=simple
ExecStart=/path/to/your/application
[Install]
WantedBy=multi-user.target
After creating your service file (e.g., myapp.service
) in /etc/systemd/system/
, you can enable and start your service with:
# Enable your service to start on boot
sudo systemctl enable myapp.service
# Start your service immediately
sudo systemctl start myapp.service
If your service doesn’t start, check its status and logs for errors:
sudo systemctl status myapp.service
journalctl -u myapp.service
Regarding updating your application over Ethernet without using a micro USB each time, consider using TorizonCore with OSTree and Docker. TorizonCore supports OTA (Over-The-Air) updates, allowing you to update your application remotely. You can package your application in a Docker container and deploy it across your devices using the Torizon OTA system. This approach eliminates the need for physical access to the device for updates and leverages Ethernet for software deployment.
To transition to using TorizonCore with OTA updates for your application, you would:
- Package your application in a Docker container.
- Use the Torizon OTA web interface to manage and deploy your application updates to your devices.
This setup streamlines the update process, making it more efficient and less error-prone than manual updates via USB.
Toradex AI Assistant
How to Autorun Application at the Start up in Linux | Toradex Developer Center.
How did you like my response?
