I know how to use AutoRun folder to have some applications or batch files running at the boot.
I have an AutoRun folder in /FlashDisk and I know how to use another AutoRun folder od SD card to lauch other applications.
My application uses USB Mass Storage class (and so ActiveSync is not available) and I can’t access to AutoRun inside /FlashDisk. I can access to SD card only.
For debug purposes I need to avoid that some of the applications in /FlashDisk/AutoRun are launched.
Is there a way to do this using (as an example) another AutoRun folder on SD Card?
I saw this KB, but I can’t connect the keyboard and I can’t edit the registry.
Is there a way to be informed if the Launcher failes in some way?
I suspect some kind of timing issues between AutoCopy and AutoRun, but it’s difficult to debug.
The application worked for some months and suddenly it’s not started anymore.
A couple of times, deleting everything on the SD card helped, but most of the times nothing changes.
Any idea?
