Is it possible to add additional SPI chip select lines on an Apalis iMX6 + Ixora Carrier Board?
Hi all,
I am new to arm embedded linux.
It it possible to add a 2nd (or more) SPI chip select lines to one SPI interface?
The Ixora carrier board offers one SPI interface on the X27 connector with one chip select line (SPI1_CS).
since I want to connect at least two SPI slave devices I would like to have more chip select lines.
I know that I have to modify the device tree files in order to enable more chip select lines, but I do not know how.
Has somebody an example file for that purpose?
Is every GPIO (of the X27 connector) able to be used SPI chip select line or do I have to consider some kind of restrictions?
Thanks in advance.
Dieter
Hi Dieter
Look at this community post for having two Spi slaves on imx6. For the device tree customization have a look here.
Thanks for your hints. I will have a look at it.
