I’ve faced an issue regarding iptables configuration. Due to the fact that one of my containers is communicating via UDP on ports that are configurable I cannot use ports binding in docker-compose files. Rader than that I came across solution to tweak with iptables on my own to accomplish kind of dynamic port binding.
Unfortunatelly I cannot change host’s machine iptables from container. I am running the container in network mode “host” with NET_ADMIN and NET_RAW capabilities added - as far as I’m concerned this should be enough to see host’s iptables rules inside the container.
Here are sample iptables rules on the host machine:
apalis-imx6-10767568:~$ sudo iptables --list
Password:
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- anywhere anywhere
RETURN all -- anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
DROP all -- anywhere anywhere
Chain DOCKER-USER (1 references)
and this is inside the container
torizon@apalis-imx6-10767568:/init$ iptables --list
Chain FORWARD (policy ACCEPT)
As you can see the chains are not even the same. Adding some rules inside container does not affect host’s rules and vice versa.
I found someone who claimed that older Kernel version caused the same effect. Can it be the problem or maybe there is some explanation why this is problematic?
Kacper
