Hi Toradex,
I trying to resolve a problem but have not managed to find a solution yet. I hoping you may know.
I have a T20 running WEC7 2.2 DHCP Enabled.
The problem is:
If I power up with a network connected to a DHCP Server, all is good (IP address assigned).
If I power up with a network connected, but no DHCP server(locally isolated switch), the T20 uses and Auto assigned IP. (which is not the problem).
If I then reconnect the switch to a DHCP server, the T20 does not get a new address from the DHCP server.Auto IP address remains.
I have tried disabling the AutoIP. This results in a 0.0.0.0 IP address, but once connected to a DHCP server the 0.0.0.0 remains.
My two options for recovery are the reboot the T20 or remove and refit the network cable from the T20.
I don’t think this is related to the build of OS as I have tried earlier versions and had the same result.
