The ethernet controller of our hardware has an enable pin (active low) which I currently enable (turn low) from the application. I found that the LCD display and LED backlight is turned ON under OS control lately.
Can I make an IO pin low under similar OS control like LCD display which will automatically go low after the OS boots up? Which registry setting is required for that?
