Hi folks,
I recently bought a new EDT Display (ETM0350G9EDHA) which is connected to our custom board with an Apalis Imx6Q 1GB module with Kernel-Version: toradex_4.9-2.3.x-imx. The question is how to set the LCD1_DE to active low in the device tree. Thank you.
Hi @farooq !
You can find it in
From the device tree of Apalis iMX6, we can see that we have the display-timings
It is defined inside an &ldb
node, which uses the compatible fsl,imx6q-ldb
, as we can see from its definition:
According to its documentation:
We can see that there is the de-active
in the display-timings
that ldb
uses:
So you can test the de-active
field values to have LCD1_DE set to active low.
