I have a Colibri iMX6DL 512MB V1.1A and the [upload|EtskpQ+Cc/Hm7PjM07HTzQMsRJg=] carrier board. I want flash linux image to the board using SD card.By running update.sh file i created the sd card .
[upload|3D/6tDiU8c9XpMjbWtxb7u6FHMo=] After that i inserted sd card into board and enter into the U-Boot prompt using UART_A then they said to run “run setupdate” command for that i am getting inavlid command
“run setupdate” is a uBoot (bootloader fo linux) command and the image(imx62.png) says that you are using eBoot(WinCE bootloader). Due to this reason it is printing “invalid command”.
I recommend you to have a look at this flashing procedure for your Colibri iMX6DL
