Compiler is complaining about missing definition for IOCTL_HAL_GPIO2IRQ and IOCTL_HAL_IRQEDGE. I guess these have been specifically defined for the PXA320 - is there an equivalent value for the iMX6?
GPIO_LEVEL_HIGH is also defined at the top of this source file, but will this value still be valid for the iMX6?
The one that contains the TORADEXIMX6BIN folder? Yes, and this has been copied to the C:\WINCE800 folder - followed the comment in https://www.toradex.com/community/questions/32319/workspace-setup.html . However, the SRC folder in the BSP download does not contain any sources. Is there a BSP download that contains the sources? The one I downloaded is version 1.6. Do the BSP sources have the required definitions?
