I’ve been experiencing a recurring issue with my eth0 interface, where it intermittently freezes, leading to domain resolution problems. To temporarily resolve the issue, I’ve been using the dhclient eth0 command. However, I’m seeking a more permanent solution and would greatly appreciate your insights.
I’ve already taken a few troubleshooting steps, including checking connectivity, reviewing system logs. Despite these efforts, the problem persists.
The only thing I changed to make this interface obtain an IP address dynamically is as follows:
If anyone has encountered a similar issue or has suggestions for further diagnostics or solutions, your assistance would be invaluable. and any guidance or input you can provide would be highly appreciated.
Thanks for your answer!
My journalctl doesn’t show much, but I noticed that the dhclient service is inactive, Could this be the origin of the issue?.
Here’s the output of the tdx-info command
