I have used the Link here to configure my device tree for supporting a 4x3 Matrix keypad. I am sharing a part of my carrier board level device tree. We are using Row 2, 4, 6, 7 and Cols 2, 4, 5.
iomux{
pinctrl_kpp: kppgrp {
fsl,pins = <
MX6QDL_PAD_KEY_ROW2__KEY_ROW2 0x1b010
MX6QDL_PAD_KEY_ROW4__KEY_ROW4 0x1b010
MX6QDL_PAD_GPIO_2__KEY_ROW6 0x1b010
MX6QDL_PAD_GPIO_5__KEY_ROW7 0x1b010
MX6QDL_PAD_KEY_COL2__KEY_COL2 0x110b0
MX6QDL_PAD_KEY_COL4__KEY_COL4 0x110b0
MX6QDL_PAD_GPIO_19__KEY_COL5 0x110b0
&kpp { /* Keypad */
compatible = "fsl,imx6qdl-kpp", "fsl,imx21-kpp";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_kpp>;
clocks = <&clks IMX6QDL_CLK_DUMMY>;
linux,keymap = <
MATRIX_KEY(0x0, 0x0, KEY_NUMERIC_1)
MATRIX_KEY(0x0, 0x1, KEY_NUMERIC_2)
MATRIX_KEY(0x0, 0x2, KEY_NUMERIC_3)
MATRIX_KEY(0x1, 0x0, KEY_KP4)
MATRIX_KEY(0x1, 0x1, KEY_KP5)
MATRIX_KEY(0x1, 0x2, KEY_KP6)
MATRIX_KEY(0x2, 0x0, KEY_7)
MATRIX_KEY(0x2, 0x1, KEY_8)
MATRIX_KEY(0x2, 0x2, KEY_9)
MATRIX_KEY(0x3, 0x0, KEY_NUMERIC_STAR)
MATRIX_KEY(0x3, 0x1, KEY_NUMERIC_0)
MATRIX_KEY(0x3, 0x2, KEY_NUMERIC_POUND)
I also changed the imx_keypad.c file to have 4x3 (rowsxcolumns) and compiled the uImage.
As of now I am able to see the keypad device in the linux userspace. I am using evtest for testing purpose.
root@colibri-imx6:~# evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: 20b8000.kpp
/dev/input/event1: stmpe-ts
/dev/input/event2: gpio-keys.29
Select the device event number [0-2]: 0
Input driver version is 1.0.1
Input device ID: bus 0x19 vendor 0x0 product 0x0 version 0x0
Input device name: "20b8000.kpp"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 8 (KEY_7)
Event code 9 (KEY_8)
Event code 10 (KEY_9)
Event code 75 (KEY_KP4)
Event code 76 (KEY_KP5)
Event code 77 (KEY_KP6)
Event code 512 (KEY_NUMERIC_0)
Event code 513 (KEY_NUMERIC_1)
Event code 514 (KEY_NUMERIC_2)
Event code 515 (KEY_NUMERIC_3)
Event code 522 (KEY_NUMERIC_STAR)
Event code 523 (KEY_NUMERIC_POUND)
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Key repeat handling:
Repeat type 20 (EV_REP)
Repeat code 0 (REP_DELAY)
Value 250
Repeat code 1 (REP_PERIOD)
Value 33
Properties:
Testing ... (interrupt to exit)
I assume at this point, if I press any key on kepad it should show up in the testing area of evtest. I don’t know what is the problem in this case.
Why in this link the row 2 pad control is different from the first two rows?
Thank you in advance.
