Hello! Great to hear about your telemetry project with the Colibri iMX8M Plus module. Let me address your questions about cloud integration and security with Torizon.
Device-to-Cloud Communication Security
Cellular Connectivity Security
For secure LTE communication, Torizon OS provides ModemManager out-of-the-box for managing cellular connections (1). You can establish secure cellular connections using:
# nmcli c add type gsm ifname * con-name home apn wap.tracfone
(1)
This provides a foundation for secure data transmission over cellular networks.
Network Management
NetworkManager works in combination with ModemManager to automatically establish connections when modems are detected (1). For production deployments, you should configure connection retries for reliable connectivity:
# nmcli connection modify <connection-name> connection.autoconnect-retries 0
(1)
Cloud Integration Tools and Platform
Torizon Platform Services
Torizon provides comprehensive cloud integration through Torizon Cloud (formerly Torizon Platform) (2). This platform offers:
- Highly secure and reliable remote updates (2)
- Fleet monitoring and remote access (2)
- Device monitoring that provides cryptographically guaranteed secure insights into device performance, behavior, and reliability (2)
Container-Based Architecture
Torizon uses Docker software containerization, giving you access to Docker Hub and thousands of ready-to-use containers (2). This makes integrating third-party cloud services and libraries much easier for your telemetry application.
OTA Updates with Version Control and Rollback
Automotive-Grade Security
Torizon’s update system is based on the Uptane standard built for automotive applications and is audited for security (2). This provides the foundation for secure OTA updates you’re looking for.
Fault-Tolerant Updates
Torizon is designed for critical, high-value systems and includes:
- Fault-tolerant recovery system for highest reliability (2)
- Automatic restoration to known good state if required (2)
- Hardware watchdog integration for extra reliability in worst-case scenarios (2)
Update Management
The platform offers nightly, monthly, quarterly and LTS releases tested on Toradex SoMs (2), providing you with flexible update scheduling options.
Production Deployment Considerations
For production deployments, you can use TorizonCore Builder to create custom images with pre-provisioned containers (3). This allows you to package your telemetry application directly into the OS image for streamlined deployment.
Recommendations
- Leverage Torizon Cloud for integrated fleet management and secure OTA updates
- Use containerized applications to simplify cloud service integration
- Implement cellular connectivity with ModemManager for reliable field deployment
- Take advantage of the open API for integrating with your existing cloud infrastructure
The Torizon platform provides an end-to-end solution that addresses all your requirements for secure telemetry, cloud integration, and reliable OTA updates.
