Integrating Hailo with yocto recipes
Dear community,
I am trying to integrate HAILO into my system. I am using BSP 6.3.0 and following the indications of this blog.
I have included the following lines in local.conf
HAILO_SOC_NAME = "hailo8"
IMAGE_INSTALL:append = " libhailort hailortcli pyhailort libgsthailo hailo-pci hailo-firmware"
IMAGE_INSTALL:append = " gstreamer1.0 gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad"
IMAGE_INSTALL:append = " v4l-utils"
After running the recipe to generate the new image, the system throws an error indicating that no recipe is found for the hailo-firmware module.
bitbake hailo-firmware
ERROR: Nothing PROVIDES 'hailo-firmware'. Close matches:
  ethos-u-firmware
  linux-firmware
  ti-rtos-firmware
I have checked the hailo repository and there is no recipe for this module.
Could someone please tell me how to resolve this error? @allan.tx
Thanks to all of you for your collaboration.
Julián
Hello Julián,
Thank you for your detailed question!
The error indicates that Bitbake cannot find a recipe called hailo-firmware. This is typically because the required meta layers providing this recipe have not been added to your Yocto build environment yet.
Here’s how to resolve the issue:
1. Clone the Required Meta Layers
To integrate Hailo, you must first clone the necessary meta layers from their repositories into your layers or sources directory:
git clone https://github.com/hailo-ai/meta-hailo.git -b kirkstone
git clone https://github.com/OSSystems/meta-gstreamer1.0.git -b kirkstone
git clone https://github.com/toradex/meta-toradex-framos.git -b kirkstone
2. Add the Layers to Your Build
Within your Yocto build environment, add the downloaded layers using the bitbake-layers command:
bitbake-layers add-layer meta-hailo/meta-hailo-accelerator
bitbake-layers add-layer meta-hailo/meta-hailo-libhailort
bitbake-layers add-layer meta-hailo/meta-hailo-tappas
bitbake-layers add-layer meta-hailo/meta-hailo-vpu
bitbake-layers add-layer meta-toradex-framos
bitbake-layers add-layer meta-gstreamer1.0
3. Confirm Recipe Presence
After adding these layers, you can check for the presence of the hailo-firmware recipe:
bitbake-layers show-recipes | grep hailo
You should now see hailo-firmware listed.
4. Build Your Image
Now, when you add hailo-firmware to IMAGE_INSTALL, Bitbake should find the recipe and include it in your image.
Reference
You can follow these steps as outlined in the official Toradex blog post for Hailo integration:
Accelerating Edge AI with Hailo
Summary:
The error occurs because the meta-hailo layers, which provide the hailo-firmware recipe, are not present in your build environment. Clone them as described, add via bitbake-layers add-layer, and the issue will be resolved.
Let me know if you need further assistance!
Toradex AI Assistant
Hi @jbruno
Seems like they removed it in the latest release (5 days ago).
It’s there in the v4.17 branch.
But we still need to check why this was removed in v5.0.0, and what’s the current recommended approach.
Hi @allan.tx ,
Any news? Any information would be welcome.
Julián
Hi @jbruno
I just checked the HailoRT v5.0.0 changelog.
Starting July 2025, support for Hailo-8, Hailo-8R, and Hailo-8L devices will be available only in HailoRT version 4.x.
So, were you able to test using v4.17?
Did you have any issues with it?
Dear @allan.tx,
Through our Hailo module distributor, we have received this response from the manufacturer:
Your customer probably needs to use the hailo8-krikstone branch.
We have integrated it into our YOCTO image and it has worked. What we do not have on board is the hailocli command that you show in the blog. Instead, we have the hailortcli and hailo commands on board.
We still have to perform performance tests, but everything seems to indicate that using this branch is the solution.
Julián
Hi @jbruno
Thank you for the information. We’ll check this.
Glad to know that it is working. I think it is just a different alias for the command.
