I tried to install Instant Boot demo on T20 and got error from nvflash tool.
Do you like to program:
1) 256MB module
2) 512MB module
2
已复制 1 个文件。
已复制 1 个文件。
已复制 1 个文件。
Nvflash version 2.0 started
rcm version 0X20001
System Information:
chip name: t20
chip id: 0x20 major: 1 minor: 3
chip sku: 0x8
chip uid: 0x042800c5405fe297
macrovision: disabled
hdcp: enabled
sbk burned: false
dk burned: false
boot device: nand
operating mode: 3
device config strap: 0
device config fuse: 4128
sdram config strap: 0
sending file: ColibriTegra2_333.bct
- 4080/4080 bytes sent
ColibriTegra2_333.bct sent successfully
downloading bootloader -- load address: 0x8300000 entry point: 0x8300000
sending file: loader.nb0
| 695896/695896 bytes sent
loader.nb0 sent successfully
waiting for bootloader to initialize
bootloader status: success (code: 0) message: flags: 1073880940
bootloader failed NvError 0x0
command failure: bootloader download failed
On console of T20, it stoped when printing these content:
Nand Block dev ioctl opcode=NvDdkBlockDevIoctlType_MapLogicalToPhysicalSector error 0x14001C
Nand block driver: Read Error = 0x14001C, PartId=3399902698, Read: start=0x300, sector count=0x1
PartitionTableInit Failed for CE6 (e=4)
Toradex Bootloader 0.1 BETA 5 for Colibri Built Jul 14 2011
RAM: 512 MB, CarveOut: 64 MB
Initiating 3P server.
The nvflash tool came from http://files.toradex.com/Colibri/WinCE/Special/nvflash.zip as said in ReadMe file.
Even with nvflash_2.2_920 flahing V2.0 WinCE7 image, the moduel entered into recovery mode directly after successful flashing. The log for flashing v2.0 image is
Toradex NVFlash Update Script
Nvflash version 2.2 started
rcm version 0X20001
System Information:
chip name: t20
chip sku: 0x8
chip uid: 0x0000000000000000042800c5405fe297
hdcp: enabled
jtag: enabled
sbk burned: false
dk burned: false
boot device: nand
operating mode: 3
Sending generated BCT...Done
downloading bootloader -- load address: 0x08300000 entry point: 0x08300000
\ 463692/463692 bytes sent
bootloader downloaded successfully
setting device: 0 0
deleting device partitions
creating partition: BCT
creating partition: PT
creating partition: EBT
creating partition: EB2
creating partition: IM2
creating partition: BMP
creating partition: CE6
creating partition: ARG
creating partition: REG
creating partition: USR
sending file: EBOOT.NB0
\ 503568/503568 bytes sent
EBOOT.NB0 sent successfully
- 503568/503568 bytes sent
sending file: Splashscreen.bmz
- 4426/4426 bytes sent
Splashscreen.bmz sent successfully
sending file: NK_CE7.NB0
- 25895460/25895460 bytes sent
NK_CE7.NB0 sent successfully
Sending Sync...
Sync Successful
