I am trying to install PJSIP on my Colibri iMX7 with Ubuntu 16.04 but I have some problems…
This is my recipe.
And the problems I have are :
- Sometimes Yocto seems to compile without taking note of my layer and sometimes yes…
I do have added my layer in the bblayers file because sometimes the changes I do in my recipe are in my image but most of the time not…
- For installing the python library of PJSIP we have to do
make or
python setup.py install in the pjsip-apps/src/python/ folder.
Why this in the recip:
cd ${S}/pjsip-apps/src/python
oe_runmake
It’s not working? (I say so because if I do python --> import pjsua
on the target it’s not working) How can I install it without doing
it by hand after : cp -r ${S}/pjsip-apps/src/python/* ${D}/usr/pjsip-python --no-preserve=ownership in the recip ?
Thank you for your help !
Can’t I just install the files with make in a tmp-folder and install them manually ? I tried with DESTDIR but it’s not working..
Creating two recipe and distutils bbclass in the python folder. That will change the behavior of OpenEmbedded: It will try to build a package from the python module…
There are some notes in the Yocto reference manual. Questions such as this on StackOverflow might help, or looking at other examples which use distutils (grep for require distutils). Otherwise studying the source might help too…
I’m think I’m having the same issue but I’m using Colibri iMX6. Can you confirm I need to use solution proposed in 2.?
I created a layer for pjsip and used a .bb from this post:
https://www.toradex.com/community/questions/9917/cross-compile-pjsip-colibri-imx7.html
Here is the error I get when I try $bitbake pjsip
| make[2]: Leaving directory ‘/home/aaron/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/pjsip/2.6-r0/pjproject-2.6/pjsip-apps/build’
| make[1]: Leaving directory ‘/home/aaron/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/pjsip/2.6-r0/pjproject-2.6/pjsip-apps/build’
| NOTE: make
| python setup.py build
| running build
| running build_py
| running build_ext
| error: invalid Python installation: unable to open /home/aaron/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/pjsip/2.6-r0/recipe-sysroot/usr/lib/python2.7/config/Makefile (No such file or directory)
| Makefile:2: recipe for target ‘all’ failed
| make: *** [all] Error 1
| ERROR: oe_runmake failed
| WARNING: /home/aaron/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/pjsip/2.6-r0/temp/run.do_compile.25391:1 exit 1 from ‘exit 1’
| ERROR: Function failed: do_compile (log file is located at /home/aaron/oe-core/build/tmp-glibc/work/armv7at2hf-neon-mx6qdl-angstrom-linux-gnueabi/pjsip/2.6-r0/temp/log.do_compile.25391)
ERROR: Task (/home/aaron/oe-core/build/../layers/meta-pjsip/recipes-pjsip/pjsip/pjsip_2.6.bb:do_compile) failed with exit code ‘1’
NOTE: Tasks Summary: Attempted 1817 tasks of which 1816 didn’t need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
Hi aaron
Welcome to the community. Can you please ask a new question? Thanks.
By the way, the solution proposed in the community post worked.
