Kindly provide me the steps to install my customised embedded linux build using buildroot to install into colibri T30
Have you seen this article - Flashing Embedded Linux to Tegra Modules?
You could follow this article but instead of using the rootfs from a master module to be cloned you may use your custom built buildroot one.
