Installing Apache via Yocto
Hello all,
Is there an established way of adding Apache to an (Colibri iMX6) image via the Yocto/OE build system?
I’m guessing I need to add a layer/recipe for this?
Richard.
You can use the IMAGE_INSTALL_append variable in local.conf.
First, edit ‘conf/bblayers.conf’ to add the meta-webserver layer:
BBLAYERS ?= " \
  ${TOPDIR}/../layers/meta-openembedded/meta-webserver \
Then, in ‘conf/local.conf’, add:
IMAGE_INSTALL_append = " apache2"
Finally, use bitbake to rebuild the image.
Great, thanks, I shall give that a try this evening!
I’ve hit an error already, any idea how I might resolve this?
Parsing recipes: 100% |##########################################################| Time: 00:04:55
Parsing of 2475 .bb files complete (0 cached, 2475 parsed). 3072 targets, 173 skipped, 0 masked, 0 errors.
ERROR: Nothing RPROVIDES ‘apache2’ (but /home/richard/workspace/bsp-toradex-v2.6.1-lxde/build/../layers/meta-toradex-demos/recipes-images/images/angstrom-lxde-image.bb RDEPENDS on or otherwise requires it)
NOTE: Runtime target ‘apache2’ is unbuildable, removing…
Missing or unbuildable dependency chain was: [‘apache2’]
ERROR: Required build target ‘angstrom-lxde-image’ has no buildable providers.
Missing or unbuildable dependency chain was: [‘angstrom-lxde-image’, ‘apache2’]
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
@riph72 I apologize, I may have been wrong about meta-webserver being configured by default in our build system. Edit bblayers.conf, and add the following to BASELAYERS:
${TOPDIR}/../stuff/meta-openembedded/meta-webserver \
I will update the answer accordingly.
Seems happy now, thanks. Note though, I modified your answer slightly and used this:
BBLAYERS = …
(I think your answer might be related to an older setup?)
Yes, you are correct, I’ve updated the answer accordingly. Thanks for the follow up.
