After the installation of the MVTEC Halcon image from recovery mode on the Apalis TK1 and a power cycle, the Apalis TK1 doesn’t start properly. The connected screen remains dark and on the host-pc the output from the attached picture is generated.
Thank you very much for your help.
Kind regards
Marco Grossmann
In the meantime I tried it again and got the following output on my console:
Here also as txt-file
link text
Hi @produktion and Welcome to the Toradex Community!!
Regarding your error you have to reset the U-Boot environment by the following commands:
- env default -a
- saveenv
After these command you can restart or do a power-cycle of the module.
