I am using Colibri-iMX6ULL_Reference-Multimedia-Image-Tezi_5.4.0+build.11 for wi-fi functionality on IMX6ULL (512 Mb) device
I want to know procedure to install and remove the packages from this image or procedure to create the customized filesystem with the required packages
Please refer below article to build custom embedded linux image using Yocto framework. We provide meta layers for our module support and reference recipe for building image. From there one can customise as per the requirement.
Let me know if you have any queries.
Ritesh Kumar
