I have tried to install the ‘libdbus-glib-1-dev’ or ‘libdbus-glib-1-staticdev’ or dbus-dev using opkg and getting below error.
What could be the problem ?
Collected errors:
* calculate_dependencies_for: Cannot satisfy the following dependencies for libdbus-glib-1-dev:
* udev (= 1:230+git0+3a74d4fc90-r0.0) *
* opkg_solver_install: Cannot install package libdbus-glib-1-dev.
root@apalis-imx6:/cups-filters#
Trying to install the cups-filter which needs dbus as dependency package.
checking for DBUS... no
configure: error: Package requirements (dbus-1) were not met:
No package 'dbus-1' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables DBUS_CFLAGS
and DBUS_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
