To install an NTP server on a Toradex Verdin iMX8M Plus, you have a couple of options depending on your preferences and the specifics of your project. Both ntp daemon and chrony are popular choices for time synchronization and can be used effectively on your board.
Installing NTP daemon or Chrony Directly on the OS
Customizing the OS Image with Yocto Project: You can include ntp or chrony directly into your custom OS image using the Yocto Project. This involves adding the package to your local.conf or your image recipe. For chrony, you would add chrony to your IMAGE_INSTALL append in the local.conf file like so:
IMAGE_INSTALL_append = " chrony"
For ntp, replace chrony with ntp in the above line. This method integrates the NTP server directly into your OS, ensuring it’s available from the first boot without requiring additional installation steps.
Using TorizonCore with Debian Containers: If you’re using TorizonCore, you can leverage the Debian container images to install either ntp or chrony in a container. This method isolates the NTP server from the host OS, providing flexibility and ease of deployment or updates.
Creating a Container for NTP/Chrony: You can create a Debian-based container and install ntp or chrony using apt-get. Here’s a basic example of a Dockerfile to get you started:
FROM debian:buster-slim
RUN apt-get update && apt-get install -y chrony
COPY mychrony.conf /etc/chrony/chrony.conf
CMD ["chronyd", "-d"]
Replace chrony with ntp and adjust the configuration file path if you prefer to use the NTP daemon. Build and run this container on your Verdin iMX8M Plus module with TorizonCore.
Recommendation
For Simplicity and Ease of Use: If you’re looking for the simplest setup and integration into your system, customizing the OS image with Yocto to include chrony or ntp is straightforward and efficient.
For Flexibility and Isolation: If you prefer to keep your time synchronization service isolated or plan to deploy updates independently of the OS, using a container with
As the @ToradexAI put, both approaches would be possible when using Torizon OS.
That being said, we typically recommend that containers are used for adding new applications or libraries to Torizon OS if possible.
The reason for this is that using containers avoids setting up a Yocto build environment and reduces the maintenance overhead when creating new releases.
That’s clear, I understand. That’s exactly what we do with our customer applications.
We are realizing that setting up a Yocto build environment is really complicated… On the other hand, we need to solve the problem that the board time is managed and controlled from a container (it should be the other way around IMHO).
