Install gui on torizon
How do you get the gui to load in torizon? tried to follow the guide on youtube but cannot find package python3-pyside2.qtgui. Although on this video there is already a gui so think that is something else. Limited experience with Linux
Greetings @stephenh,
I assume you’re referring to the following video: https://www.youtube.com/watch?v=hwCXSckISXM
The GUI you see in this video when the python packages are being installed is actually a development PC connected to the Torizon device over serial.
The how-to written guide that the video was based off of is available here: High performance, low power Embedded Computing Systems | Toradex Developer Center
It is important to remember that for installing packages using a package manager you want to be in a container system that allows for it. The following command (also listed in the documentation above) will put you in a Debian based container with a suitable package manager:
docker run -it --privileged \
                -v /dev:/dev debian:buster /bin/bash
You’ll know you’re in the container as opposed to the base system when you’re terminal prompt is preceded by root@1234567 instead of root@apalis-imx6-1234567. Also there is now Torizon related documentation (Torizon | Toradex Developer Center) published on our developer site.
