The system can’t identifed the adapter.
Here are the dmesg
dmesg | grep usb
[ 0.136113] usbcore: registered new interface driver usbfs
[ 0.136283] usbcore: registered new interface driver hub
[ 0.136472] usbcore: registered new device driver usb
[ 0.861801] usbcore: registered new interface driver usb-storage
[ 0.868132] usbcore: registered new interface driver usbserial
[ 0.874136] usbcore: registered new interface driver usbserial_generic
[ 0.880795] usbserial: USB Serial support registered for generic
[ 0.886979] usbcore: registered new interface driver ftdi_sio
[ 0.892879] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 0.900356] usbcore: registered new interface driver pl2303
[ 0.906102] usbserial: USB Serial support registered for pl2303
[ 0.914255] 40034000.usb supply vbus not found, using dummy Regulator
[ 0.967976] 400b4000.usb supply vbus not found, using dummy regulator
[ 1.137217] usbcore: registered new interface driver usbhid
[ 1.142870] usbhid: USB HID core Driver
[ 12.091878] usb 1-1: new high-speed USB device number 2 using ci_hdrc
Here are the lsusb
lsusb
Bus 002 Device 001: ID 1d6b:0002
Bus 001 Device 002: ID 0bda:8179
Bus 001 Device 001: ID 1d6b:0002
Here are lsmod
lsmod
Module Size Used by
can_raw 6781 1
can 29091 1 can_raw
virtio_rpmsg_bus 11294 0
flexcan 8843 0
can_dev 12251 1 flexcan
usb_f_rndis 15406 2
u_ether 11849 1 usb_f_rndis
usb_f_acm 5319 2
u_serial 9574 3 usb_f_acm
vf610_rpmsg 4366 0
virtio_ring 10779 2 virtio_rpmsg_bus,vf610_rpmsg
virtio 7347 2 virtio_rpmsg_bus,vf610_rpmsg
rtc_pcf8563 6201 0
libcomposite 43368 12 usb_f_acm,usb_f_rndis
configfs 23333 4 usb_f_acm,usb_f_rndis,libcomposite
