Hello
I have build yocto image on my imx7D, and i want to install AWS greengrass on it. Please tell me yocto customizations for the same. I want to know which layers and recipies to add to be able to provide required packages for greengrass.
hi @garima09
Hello I have build yocto image on my imx7D, and i want to install AWS greengrass on it.
Which git branch did you use to compile your yocto image?
If you use the rocko branch, then to include GreenGrass in your Image, you can simply add this package to your custom image. You need to add the also the meta-digi-dey
layer in the bblayers.conf
