Inquiries for Reliability Data (MTBF & FIT) for APALIS IMX8Q 4GB IT
We would like to request the reliability data (MTBF and FIT) for the APALIS IMX8Q (MPN: 00471104 & 0471103).
Kindly help to advise the condition used (Confidence Level, Temperature, and Activation Energy).
Thank you.
Thank you for your inquiry regarding the reliability data for the Apalis iMX8Q module. Typically, detailed reliability metrics such as MTBF (Mean Time Between Failures) and FIT (Failure In Time), along with the conditions like confidence level, temperature, and activation energy, are not included in standard documentation. These metrics are usually derived from specific internal testing processes.
While I am unable to provide this data directly, I hope this information helps clarify the typical availability of such data.
https://www.toradex.com/computer-on-modules/apalis-arm-family/nxp-imx-8
RS485 send too much data.
MTBF and Failure Rate predictions are presented in the following Tables for the Apalis iMX8QM 4GB IT as per Telcordia SR-332.
Environment Temperature MTBF (hours) MTBF (years) Failure Rate (FIT)*
GB 25°C 5,918,245 675.6 168.97
GB 40°C 3,333,400 380.5 299.99
GF 25°C 2,959,123 337.8 337.94
GF 40°C 1,666,700 190.3 599.99
GM 25°C 900,463 102.8 1,110.54
GM 40°C 493,669 56.4 2,025.65
Alexander Samutin
Toradex
