Hi Toradex Team ,
I am able to flash the build kernel image on the SD card and boot the board .
But the setup throws below mentioned console message on the screen & i am not getting any display. root@apalis-imx6:~# uname -a
Linux apalis-imx6 3.14.52-v2.6.1b1+g3894f6d #1 SMP Thu Jan 12 16:22:15 IST 2017 armv7l GNU/Linux
root@apalis-imx6:~# [ 27.442270] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 27.503559] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 27.574334] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 27.643510] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 27.713798] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 33.232863] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 33.293524] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 33.364302] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 33.433497] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz [ 33.503789] mxc_sdc_fb fb.20: 640x480 h_sync,r,l: 96,16,48 v_sync,l,u: 2,10,33 pixclock=25200000 Hz
