Initializing LAN9252 as a ethercat slave
Hi community..!
i am using Toradex-colibri evaluation board IMX7 like i am working on ethercat communication using spi by spidev python library
I have working code on C in that everything is working good now i converted that code into python initialization itself failed can you please help me to fix this issue like some basic code for lan9252 with toradex some sample codes
here is the code for ur reference
RESET_CTL = 0x01F8
DIGITAL_RST = 0x00000001
ETHERCAT_RST = 0x00000040
initialize / check the etc interface on SPI, return true if initialization is ok
def etc_init():
TempLong = ULONG()
Etc_Write_Reg(RESET_CTL, (DIGITAL_RST & ETHERCAT_RST)) # Need to check "AND" Operator
time.sleep(0.3)
TempLong.LANLong = Etc_Read_Reg(BYTE_TEST, 4)          # read test register
if TempLong != 0x87654321:
    print("Bad response received from Etc Test command, data received =", TempLong.LANLong)
    return False
TempLong.LANLong = Etc_Read_Reg(HW_CFG, 4)        # check also the READY flag
if((TempLong.LANLong & READY) == 0 ):
    print("Ready not received from Etc HW Cfg, data received =", TempLong.LANLong)
    return False
print("Etc Test Command succeeded\n")
return True
def Etc_Read_Reg(address, length):
Result = ULONG() # Initialize Result as ULONG instance
Addr = UWORD() # Initialize Addr as UWORD instance and set address
xfrbuf = (ctypes.c_uint8 * 7)() # Create buffer for SPI transfer
Addr.LANWord = address
xfrbuf[0] = COMM_SPI_READ  # SPI read command
xfrbuf[1] = Addr.LANByte[1]  # Address high byte
xfrbuf[2] = Addr.LANByte[0]  # Address low byte
for i in range(length):
    xfrbuf[i + 3] = DUMMY_BYTE  # Fill dummy bytes after address bytes
response = spi.xfer2(list(xfrbuf))  # Perform SPI transfer and receive response
    Result.LANByte[i] = response[i + 3]  # Assign received bytes to Result.LANByte[i]
return Result.LANLong
write a directly addressable register, 4 bytes always
Address = register to write, DataOut = data to write
def Etc_Write_Reg(address, DataOut):
Data = ULONG()
Addr = UWORD()
Data.LANLong = DataOut
xfrbuf[0] = COMM_SPI_WRITE     # SPI write command
xfrbuf[1] = Addr.LANByte[1]    # address of the register
xfrbuf[2] = Addr.LANByte[0]    # to read, MsByte first
for i in range(4):
    xfrbuf[i+3] = Data.LANByte[i]       # Fill data bytes, lsb
# Transmit function
def main():
# Initialize EtherCAT interface
if not etc_init():
print(“EtherCAT initialization failed”)
return
if name == “main”:
main()
Hi @uday1012,
Unfortunately, we do not have any sample code for the same either in C or in python.
