Information about kernel message
i have some doubts regarding kernel message. My target is compsed from SoM verdin imx8mp 2GB and carrier board mallow. This my tdx info:
Software summary
Kernel version:           6.6.119-7.5.0-devel-ge5c5595adb06 #1-Torizon SMP PREEMPT Mon Jan  5 09:23:13 UTC 2026
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/f2110b8ae890590f3d0d4b3d9ca84dfa84cc27e93362f4058cdd5be44cc3c8b7/0
Distro name:              NAME="Torizon OS"
Distro version:           VERSION_ID=7.5.0-devel-20260121131151-build.0
Hostname:                 verdin-imx8mp-15603379
Hardware info
HW model:                 Toradex Verdin iMX8M Plus WB on Mallow Board
Toradex version:          0064 V1.1A
Serial number:            15603379
When i start my target i see the follows message:
Starting kernel ...
[    1.039654] nvmem imx-ocotp0: cell mac-address raw len 6 unaligned to nvmem word size 4
[    1.047697] nvmem imx-ocotp0: cell mac-address raw len 6 unaligned to nvmem word size 4
Starting systemd-udevd version 255.21^
sysroot.readonly configuration value: 0 (fs writable: 1)
Using legacy ostree bind mount for /
[    6.923741] imx-bus-devfreq 32700000.interconnect: failed to fetch clk: -2
[    6.956237] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[    6.977555] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[    7.016264] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[    7.042416] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[    7.060736] fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
[    9.376727] tpm tpm0: A TPM error (256) occurred attempting the self test
Torizon OS 7.5.0-devel-20260121131151+build.0 verdin-imx8mp-15603379 ttymxc2
I see fsl-aud2htx 30cb0000.aud2htx: failed to pcm registert, imx-bus-devfreq 32700000.interconnect: failed to fetch clk: -2 and tpm tpm0: A TPM error (256) occurred attempting the self test.
Can I ignore these messages or do I need to resolve them? If I need to resolve them, what should I do?
Thanks.
Fabio
Hello Fabio,
Based on your system information, you’re running Torizon OS 7.5.0-devel on a Verdin iMX8M Plus with Mallow Carrier Board. The kernel messages you’re seeing are common and can be categorized as follows:
Message Analysis
1. imx-bus-devfreq 32700000.interconnect: failed to fetch clk: -2
This message indicates the interconnect driver failed to fetch a clock reference. This is typically harmless and doesn’t affect system functionality. The error code -2 usually means the clock isn’t available or properly configured in the device tree, but the system continues to operate normally.
2. fsl-aud2htx 30cb0000.aud2htx: failed to pcm register
These messages relate to the audio subsystem (AUD2HTX - Audio to HDMI TX). Since you’re using the Mallow Carrier Board, which doesn’t have HDMI output capabilities, this audio component isn’t needed. The driver attempts to register but fails because the hardware path isn’t complete on this carrier board configuration.
3. tpm tpm0: A TPM error (256) occurred attempting the self test
This message indicates the TPM (Trusted Platform Module) self-test failed. The Verdin iMX8M Plus includes TPM functionality for security features (1). However, if you’re not using security features like Secure Boot or encrypted storage, this error won’t impact normal system operation.
Recommendations
You can generally ignore these messages if:
  • Your system boots successfully and reaches the login prompt
  • Your applications function correctly
  • You don’t require audio over HDMI functionality
  • You’re not implementing security features that depend on TPM
Consider addressing them if:
  • You plan to use Secure Boot features (2)
  • You need TPM-based security functionality
  • The messages concern you from a system health perspective
Resolution Options
If you want to clean up these messages, you could create custom device tree overlays to disable unused peripherals, but this is typically unnecessary for normal operation.
The system appears to be functioning correctly based on your boot log reaching the login prompt successfully.
Greetings @fmolon,
Yes those messages you see are all normal and you should be able to ignore them safely.
Hi @jeremias.tx,
thanks for your help.
Best regards
Fabio
Glad we were able to help clarify.
