I needed more code space for an M4 application on an iMX7D. I am currently running the application out of OCRAM.
I changed the MCIMX7D_M4_ocram.ld
- from: m_text (RX) : ORIGIN = 0x00910000, LENGTH = 0x00010000
- to: m_text (RX) : ORIGIN = 0x00908000, LENGTH = 0x00017FFF
This worked perfectly. However, I am concerned that I may have taken up space allocated to other functionality that is not obvious. I see that the imx7-colibri.dtsi actually has the following declaration;
- &ocram {
reg = 0x00901000 0xf000;
I don’t know where this is used or if it will turn into a problem later.
Any help to confirm my change is valid would be helpful.
