It’s actually not CPU usage issue, is an issues with colibri monitor.
We changed the way processor idle is implemented, to solve some stability issues, and we were not able to count the time spent in idle in a reliable way. If you switch to process view you will see that the processor time used by the different processes, including the kernel, will be very low when the system is not active.
We documented the issue here:
