Increase bluettoth power in IMX8 board
I’m working on the board Apalis iMX8QP 2GB WBV1.0B mounted on the Apalis IMX8.
I installed on it an embedded Linux image developed with Yocto. All is working fine.
However, I have some problems with the Bluetooth.
I connected to the board, the antenna Chang Hong DA-2458-02RP-SMA V1.0A with the cable Antenna Cable MHF4 toRP-SMA 200mm V1.0A.
The board should find some Bluetooth sensors. The sensors are set with the highest transmission power possible. For example, with a smartphone they can be found also at a distance of 20-30 meters.
If I use the board, I can find the sensors only in a distance range of 10-20 centimeters. If I put the sensors at a distance of 1 meter, the board can’t find the sensors.
Is there a way to increase the Bluetooth power in the board?
Thank you in advance.
Hi @magmar ,
Thanks for the question.
Please be aware that the module you’re using is a Early-Access version. So there might be unpredictable behaviour.
About the Bluetooth power we’ll send you some information, as soon as possible.
Kevin
Have you tried to use 2 antennas?
Hello @magmar ,
Do you have any updates on this topic?
Josep
