On a custom carrier board for Colibri iMX6ULL 512MB Wi-Fi / Bluetooth IT V1.1A module I have bitbaked an image with minor changes/patches to u-boot. I am using BSP v3.0.4. The patches are essentially device tree change so that u-boot recognises an eMMC that we have placed on the carrier board: a device tree content and filename change. This works nicely and u-boot can see the eMMC.
Because u-boot-fw-utils appears to use the same source as u-boot (but a copy), the same patches are needed there, so the .bbappend files for u-boot and u-boot-fw-utils are essentially the same. The content of the u-boot-toradex-fw-utils_2019.07.bbappend is:
FILESEXTRAPATHS_prepend := "${THISDIR}/files/colibri-imx6ull/:"
# u-boot-toradex-fw-utils uses same source as u-boot-toradex
# so we need to apply same patches.
SRC_URI += "file://0001-uboot-config-and-device-tree-for-mycarrier.patch \
file://0002-dts-and-uboot-config-change-for-non-removable-eMMC.patch"
COMPATIBLE_MACHINE = "(colibri-imx6ull|colibri-imx6ull-mycarrier)"
The problem is that, while the resulting rootfs image contains functioning fw_printenv / fw_setenv commands, the /etc/fw_env.config file is not the colibri-imx6ull one, but rather seems to be coming from the meta-toradex-nxp/recipes-bsp/u-boot/files/mx6/fw_env.config directory.
If I copy the correct file (meta-toradex-nxp/recipes-bsp/u-boot/files/colibri-imx6ull/fw_env.config) to my host the fw_ commands work as expected but I cannot figure out why the bitbake image is not picking up the correct file.
