I was working on mounting the filesystem for a SSD attached to our carrier board when the system rebooted leaving /etc/fstab in an incomplete state.
Now when the system reboots, I get a message (as expected) on the serial port that it isn’t able to mount the SSD but then it doesn’t give me an opportunity to fix anything. What options do I have to get past this? It doesn’t bring up the portainer interface and doesn’t connect to the OTA system nor can I SSH into it.
U-Boot 2020.04-5.5.0+git.81bc8894031d (Jan 01 1970 - 00:00:00 +0000)
CPU: NXP i.MX8QM RevB A53 at 1200 MHz
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Model: Toradex Apalis iMX8 QuadMax 4GB IT V1.1C, Serial# 06945459
BuildInfo:
- SCFW 778670e2, SECO-FW d63fdb21, IMX-MKIMAGE 8947fea3, ATF 835a8f6
- U-Boot 2020.04-5.5.0+git.81bc8894031d
switch to partitions #0, OK
flash target is MMC:0
Net: eth0: ethernet@5b040000
Fastboot: Normal
Normal Boot
Scanning mmc 0:1...
Found U-Boot script /boot.scr
1182 bytes read in 13 ms (87.9 KiB/s)
## Executing script at 83100000
5967 bytes read in 28 ms (208 KiB/s)
166807 bytes read in 34 ms (4.7 MiB/s)
43 bytes read in 26 ms (1000 Bytes/s)
Applying Overlay: apalis-imx8_hdmi_overlay.dtbo
2177 bytes read in 35 ms (60.5 KiB/s)
11612693 bytes read in 279 ms (39.7 MiB/s)
Uncompressed size: 28715520 = 0x1B62A00
9176228 bytes read in 228 ms (38.4 MiB/s)
## Flattened Device Tree blob at 83000000
Booting using the fdt blob at 0x83000000
Loading Ramdisk to fcd8d000, end fd64d4a4 ... OK
Loading Device Tree to 00000000fcd41000, end 00000000fcd8cfff ... OK
Starting kernel ...
[ 0.161466] 001: No BMan portals available!
[ 0.162729] 001: No QMan portals available!
[ 1.918594] 001: imx-audmix imx-audmix.0: failed to find SAI platform device
[ 2.047617] 004: imx6q-pcie 5f000000.pcie: pcie_ext clock source missing or invalid
[ 2.048909] 003: imx6q-pcie 5f010000.pcie: pcie_ext clock source missing or invalid
[ 2.728310] 002: debugfs: Directory '59050000.sai' with parent 'apalis-imx8qm-sgtl5000' already present!
[ 3.893617] 001: imx6q-pcie 5f010000.pcie: failed to initialize host
[ 3.893626] 001: imx6q-pcie 5f010000.pcie: unable to add pcie port.
[ 4.013334] 005: imx6q-pcie 5f000000.pcie: failed to initialize host
[ 4.013341] 005: imx6q-pcie 5f000000.pcie: unable to add pcie port.
Starting version 244.5+
[ 6.087952] 001: systemd[1]: Failed to mount /var/rootdirs/mnt/gojimedia.
[ 10.617511] 000: debugfs: Directory '59090000.sai' with parent 'imx-audio-hdmi-tx' already present!
[ 10.625340] 001: debugfs: File 'Capture' in directory 'dapm' already present!
You are in emergency mode. After logging in, type "journalctl -xb" to view
system logs, "systemctl
Cannot open access to console, the root account is locked.
See sulogin(8) man page for more details.
Press Enter to continue.
Reloading system manager configuration
Starting default target
