we are using VF50 with CE8.
We are using autorun.xml file to run .exe file in our project. But it don’t work on boot up. If we copy same .exe file in AutoRun folder then it works on boot up. Please guide me instead of aurorun.xml what can be used.
Hi Madhav,
Did you check our article on AutoRun?
https://developer.toradex.com/knowledge-base/autorun
You can also use the registry to run your application at boot. This information is also provided in the article.
You can create a .lnk (shortcut) file to exe file you want to run on startup. Please see details here.
.lnk file is working okay. Thanks for your support.
Perfect that it works. Thanks for your feedback.
