Installed Toradex Easy Installer (Colibri-iMX8X_ToradexEasyInstaller_2.0b5-20200519) using the nightly TEZI build (Colibri-iMX8X_ToradexEasyInstaller_2.0b6-nightly-20201028).
- /sys/class/drm/ contains: card0,card1,card1-DPI-1,renderD128,version.
- /sys/class/drm/card1-DPI-1/modes contains: 640x480 which matches the output of
weston-info - The VGA display connected on the Iris DVI-A displays the TEZI normally.
I want to change the TEZI resolution using u-boot env variables so it can be displayed on our embedded device’s monitor at 1024x768@60 using parallel RGB.
What vidargs should I set?
