To boot from the SD card instead of the eMMC on the IMX8MP platform, you need to adjust the U-Boot environment variables. Here are the steps you should follow:
Modify U-Boot Environment Variables:
Check Boot Order: Ensure that the boot order prioritizes the SD card over the eMMC. You can do this by setting the appropriate environment variables such as bootargs and bootcmd.
Set Bootargs: Use the command setenv bootargs <your_sd_card_args> to specify the SD card as the source for the kernel and filesystem.
Set Bootcmd: Modify the bootcmd variable to ensure it attempts to boot from the SD card first. For example, you might set it to mmc dev 1; mmc read ... to specify the SD card as the boot device.
Save Changes:
After making changes to the environment variables, save them using the saveenv command to make the changes persistent across reboots.
Verify SD Card Functionality:
Use the mmc list command in U-Boot to verify that the SD card is detected.
Ensure the SD card is properly formatted and contains a valid bootable image.
By following these steps, you should be able to configure your IMX8MP platform to boot from the SD card instead of the eMMC.
