Hello! Thank you for your detailed question.
You are on the right track, but a few modifications are needed to allow the i.MX8MP to interface properly with the MAX98357A via I2S, especially on Verdin pin 30 (BCLK), 32 (SYNC), and 34 (DOUT). The “No soundcards found” message typically means that the audio subsystem is missing a compatible card or that clocks and pinmux are not set up correctly.
Here’s a working approach, based on a successful example with this hardware combination:
1. Use a Dummy Codec First
The MAX98357A does not require I2C control, so you can initially use the dummy codec (spdif-dit) driver for testing. After that you can further tune or revert the codec settings to "maxim,max98357a" if you wish.
Example node:
max98357a {
compatible = "linux,spdif-dit"; // For initial testing; can switch to "maxim,max98357a"
#sound-dai-cells = <0>;
Reference: Community Example
2. Set up the SAI1 Clocks
&sai1 {
pinctrl-0 = <&pinctrl_sai1_bclk_lrclk_dout>;
pinctrl-names = "default";
assigned-clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI1_MCLK1_SEL>,
<&clk IMX8MP_CLK_SAI1>;
assigned-clock-parents = <&clk IMX8MP_CLK_SAI1_ROOT>,
<&clk IMX8MP_AUDIO_PLL1_OUT>;
assigned-clock-rates = <12288000>, <0>;
3. Pin Configuration
Ensure the pins are muxed for SAI1 signals correctly:
&iomuxc {
pinctrl_sai1_bclk_lrclk_dout: pinctrl_sai1_bclk_lrclk_dout {
fsl,pins =
<MX8MP_IOMUXC_SAI5_MCLK__AUDIOMIX_SAI1_TX_BCLK 0x1d6>,
<MX8MP_IOMUXC_SAI5_RXD1__AUDIOMIX_SAI1_TX_SYNC 0x1d6>,
<MX8MP_IOMUXC_SAI5_RXFS__AUDIOMIX_SAI1_TX_DATA00 0x96>;
4. Complete Device Tree Overlay Example
Here is how you can bring it all together (keep your compatible settings, but update the audio and pins as below):
/dts-v1/;
/plugin/;
#include <dt-bindings/clock/imx8mp-clock.h>
#include "imx8mp-pinfunc.h"
max98357a: max98357a {
sound {
compatible = "simple-audio-card";
simple-audio-card,name = "Audio Output via MAX98357A";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&dailink_master_cpu>;
simple-audio-card,frame-master = <&dailink_master_cpu>;
simple-audio-card,codec {
sound-dai = <&max98357a>;
dailink_master_cpu: simple-audio-card,cpu {
sound-dai = <&sai1>;
&sai1 {
assigned-clocks = <&audio_blk_ctrl IMX8MP_CLK_AUDIO_BLK_CTRL_SAI1_MCLK1_SEL>, <&clk IMX8MP_CLK_SAI1>;
assigned-clock-parents = <&clk IMX8MP_CLK_SAI1_ROOT>, <&clk IMX8MP_AUDIO_PLL1_OUT>;
&iomuxc {
fsl,pins =
Note: This config provides a 48kHz clock (and related rates). For other sample rates you may need to adjust the assigned clocks.
5. Disabling Default Codec
You have correctly disabled the default codec (like nau8822) with:
&nau8822_1a {
status = "disabled";
Summary
- Update the codec node to use the dummy codec for initial verification.
- Update all SAI1 and pinmux settings as above.
- Recompile and load your overlay.
- After reboot, check
aplay -l or arecord -l and dmesg for new soundcard.
If you follow these recommendations, your soundcard should be detected and you can proceed with audio output testing.
Related resource:
https://community.toradex.com/t/i2s-output-without-codec/26845
