I’m using imx8mp + Dahlia V1.1, failed to connect to WiFi network.
I’m using the latest Torizon OS
ID=torizon
NAME=“Torizon OS”
VERSION=“7.5.0+build.30 (scarthgap)”
VERSION_ID=7.5.0-build.30
VERSION_CODENAME=“scarthgap”
PRETTY_NAME=“Torizon OS 7.5.0+build.30 (scarthgap)”
CPE_NAME=“cpe:/o:openembedded:torizon:7.5.0+build.30”
BUILD_ID=“30”
ANSI_COLOR=“1;34”
VARIANT=“Docker”
I’ve tried to reload the mwifiex_sdio driver, power cycle the board, and re-flash the image, but it still failed authentication.
Below is the system log to help debug:
[ 2009.324133] mwifiex_sdio mmc0:0001:1: info: shutdown mwifiex…
[ 2009.324248] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2009.326094] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2009.395593] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2021.884883] mwifiex_sdio mmc0:0001:1: WLAN FW already running! Skip FW dnld
[ 2021.884905] mwifiex_sdio mmc0:0001:1: WLAN FW is active
[ 2021.928558] mwifiex_sdio mmc0:0001:1: event: unknown event id: 0x81
[ 2021.928705] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
[ 2021.928714] mwifiex_sdio mmc0:0001:1: host_mlme: enable, key_api: 2
[ 2021.965058] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p137)
[ 2021.965077] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.92.21.p137)
[ 2269.070164] mwifiex_sdio mmc0:0001:1: auth: send authentication to 28:70:4e:62:85:e3
[ 2269.083454] mwifiex_sdio mmc0:0001:1: auth: receive authentication from 28:70:4e:62:85:e3
[ 2271.663420] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x10d error, result=0x1
[ 2271.663451] mwifiex_sdio mmc0:0001:1: failed to remain on channel
[ 2272.565115] mwifiex_sdio mmc0:0001:1: auth: send authentication to 28:70:4e:62:8c:4b
[ 2278.859700] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2280.591051] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2290.321574] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2294.425268] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2305.234027] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2323.375313] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2334.179037] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2352.378457] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2363.181644] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2501.009781] mwifiex_sdio mmc0:0001:1: info: shutdown mwifiex…
[ 2501.009897] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2501.011716] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2501.085790] mwifiex_sdio mmc0:0001:1: PREP_CMD: card is removed
[ 2512.104211] mwifiex_sdio mmc0:0001:1: info: FW download over, size 624880 bytes
[ 2512.935494] mwifiex_sdio mmc0:0001:1: WLAN FW is active
[ 2512.978990] mwifiex_sdio mmc0:0001:1: event: unknown event id: 0x81
[ 2512.979110] mwifiex_sdio mmc0:0001:1: Unknown GET_HW_SPEC TLV type: 0x23e
[ 2512.979117] mwifiex_sdio mmc0:0001:1: host_mlme: enable, key_api: 2
[ 2513.012364] mwifiex_sdio mmc0:0001:1: info: MWIFIEX VERSION: mwifiex 1.0 (16.92.21.p137)
[ 2513.012383] mwifiex_sdio mmc0:0001:1: driver_version = mwifiex 1.0 (16.92.21.p137)
[ 2596.215244] mwifiex_sdio mmc0:0001:1: auth: send authentication to 28:70:4e:62:85:e3
[ 2596.253444] mwifiex_sdio mmc0:0001:1: auth: receive authentication from 28:70:4e:62:85:e3
[ 2598.808253] mwifiex_sdio mmc0:0001:1: CMD_RESP: cmd 0x10d error, result=0x1
[ 2598.808282] mwifiex_sdio mmc0:0001:1: failed to remain on channel
[ 2599.635200] mwifiex_sdio mmc0:0001:1: auth: send authentication to 28:70:4e:61:8a:6e
[ 2605.938905] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2607.745731] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2617.438644] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2624.361952] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2635.159313] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2653.372264] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2686.017553] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2696.822678] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2710.203487] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2720.937541] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2738.379232] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2749.116156] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2767.385296] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2778.244235] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2796.368195] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2807.161960] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2825.375302] mwifiex_sdio mmc0:0001:1: Pending auth on going
[ 2836.223855] mwifiex_sdio mmc0:0001:1: Pending auth on going
