Hi there,
I’ve 2 dahlia v1.1 CB, and 2 verdin modules (1x imx8mm, 1x imx8mp) and i’m trying to use the usb-drp port with a USB-C to USB-A-F OTG converter to use 3 usb devices. When using the imx8mm module, there are no problems and i can see the device connected and use the USB device connected to it, but when i connect the same OTG converter with the imx8mp module the device doesn’t appear, neither event logs about it.
I’m using the same build based on tdx-wayland-multimedia-reference with 5.4.154-5.5.0-devel+git.c65f1622951c kernel. I’m only changing the MACHINE reference from imx8mm to imx8mp.
Is there any chance that imx8mp doesn’t support the usb-drp?
Regards
