Hello Andrew,
Thank you for your detailed explanation! Your approach and documentation are great, and you’re definitely on the right track. The issue likely comes from a few places in your device tree configuration and the process for ensuring the pins are functioning purely as GPIOs.
Points to Address
Pin Ownership / Peripheral Conflict
- The SPDIF_TX pin is assigned by default to the CAN1 peripheral as
CAN1_TX. Even if you change just the pinctrl values, the flexcan1 driver may still claim the pin. - Solution: Explicitly disable the
flexcan1node in your overlay or device tree.
This will prevent the kernel from attaching the CAN1 function to those pins.&flexcan1 { status = "disabled"; };
(Reference)
Pinctrl Pad Value
- The value
0x104configures the pad with “pull-down” and “SION” (software input). While this should work for a pulled-down GPIO, for output use a more typical value:0x184(output, pull-down) or0x1c4(output, pull-up), depending on your needs (Reference).
- The value
Pin Assignment to GPIO
- Ensure the pins are placed into a hog configuration so they are exported and set as outputs with initial state:
This will make the pins available as /dev/gpiochip devices and keep them low on boot.&gpio5 { gpio5_io3: gpio5_io3_output { gpio-hog; gpios = <3 GPIO_ACTIVE_HIGH>; output-low; line-name = "gpio5_io3_output"; status = "okay"; }; gpio5_io4: gpio5_io4_output { gpio-hog; gpios = <4 GPIO_ACTIVE_HIGH>; output-low; line-name = "gpio5_io4_output"; status = "okay"; }; };
(Reference: Customizing Device Trees)
Correct Header Pin Mapping
- Double-check that your pad assignments match the physical X19 pins, as some may be shared with default boot or debug functions (Reference: First Steps With Device Trees).
Recommended Device Tree Overlay Example
/dts-v1/;
/plugin/;
compatible = "toradex,verdin-imx8mp";
fragment@0 {
target = <&flexcan1>;
__overlay__ {
fragment@1 {
target = <&iomuxc>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_flexcan1_gpio>;
fragment@2 {
target = <&gpio5>;
__overlay__ {
gpio-hog;
output-low;
gpio-hog;
output-low;
fragment@3 {
target-path = "/bus@30800000/iomuxc@30330000";
__overlay__ {
pinctrl_flexcan1_gpio: pinctrl_flexcan1_gpio {
fsl,pins = <
MX8MP_IOMUXC_SPDIF_TX__GPIO5_IO3 0x184
MX8MP_IOMUXC_SPDIF_RX__GPIO5_IO4 0x184
- Use
0x184pad control for stable, output-low GPIO. - Expand the above for all pins on X19 as needed.
How to Apply and Test
- Build the overlay and apply with TorizonCore Builder.
- Reboot your device and run:
gpioinfo- Confirm your pins are correctly configured as output and low.
Further Guidance
- Make sure only overlays (not direct .dtsi edits) are used when possible, to ease migrations and updates.
- If you continue to see unexpected voltages, re-verify the physical header mapping and check for other conflicting definitions in other overlays or base trees.
References
- First Steps With Device Trees
- How to Customize Device Trees
- Changing GPIO Behaviour Using Device Tree Overlay
Please let me know if you need help adapting this for the rest of the X19 header or if you encounter further issues!
