The iMX8M Plus gets rebooted when running the rt-validation stress-test container. It reboots 15-60min after the container is started:
Boot Output:
U-Boot SPL 2020.04-5.3.0-devel+git.2e5818d88ee0 (Jan 01 1970 - 00:00:00 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 4000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from BOOTROM
Find FIT header 0x4803b000, size 969
Download 839680, total fit 840496
NOTICE: BL31: v2.2(release):toradex_imx_5.4.70_2.3.0-g835a8f67b2
NOTICE: BL31: Built : 00:00:00, Jan 1 1970
U-Boot 2020.04-5.3.0-devel+git.2e5818d88ee0 (Jan 01 1970 - 00:00:00 +0000)
CPU: i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 52C
Reset cause: POR
DRAM: 4 GiB
MMC: FSL_SDHC: 1, FSL_SDHC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Verdin iMX8M Plus Quad 4GB Wi-Fi / BT IT V1.0B, Serial# 06848946
Carrier: Toradex Verdin Development Board V1.1A, Serial# 10795103
BuildInfo:
- ATF 835a8f6
- U-Boot 2020.04-5.3.0-devel+git.2e5818d88ee0
flash target is MMC:2
Net: eth0: ethernet@30be0000, eth1: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Normal Boot
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
1182 bytes read in 9 ms (127.9 KiB/s)
## Executing script at 46000000
4727 bytes read in 12 ms (383.8 KiB/s)
85856 bytes read in 18 ms (4.5 MiB/s)
112 bytes read in 12 ms (8.8 KiB/s)
Applying Overlay: verdin-imx8mp_native-hdmi_overlay.dtbo
1860 bytes read in 20 ms (90.8 KiB/s)
Applying Overlay: verdin-imx8mp_lt8912_overlay.dtbo
2007 bytes read in 20 ms (97.7 KiB/s)
Applying Overlay: custom-kargs_overlay.dtbo
188 bytes read in 16 ms (10.7 KiB/s)
11629598 bytes read in 54 ms (205.4 MiB/s)
Uncompressed size: 28791296 = 0x1B75200
9170412 bytes read in 42 ms (208.2 MiB/s)
## Flattened Device Tree blob at 43000000
Booting using the fdt blob at 0x43000000
Loading Device Tree to 00000000fdbbc000, end 00000000fdbf3fff ... OK
Starting kernel ...
[ 0.109748] 001: No BMan portals available!
[ 0.110504] 001: No QMan portals available!
[ 1.273601] 003: samsung-hdmi-phy 32fdff00.hdmiphy: failed to get phy apb clk: -517
[ 1.273816] 003: imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clock
[ 1.301028] 003: imx-lcdifv3 32fc6000.lcd-controller: No irq get
[ 1.304096] 003: imx-hdmi-pavi 32fc4000.hdmi-pai-pvi: No pvi clock get
[ 1.367559] 003: failed to register cpuidle driver
[ 1.707156] 003: imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 1.707469] 003: dwhdmi-imx 32fd8000.hdmi: No pavi info found
[ 1.828796] 003: imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 2.863991] 002: imx6q-pcie 33800000.pcie: failed to initialize host
[ 2.863995] 002: imx6q-pcie 33800000.pcie: unable to add pcie port.
Starting version 244.5+
[ 7.105606] 002: debugfs: Directory '30cb0000.aud2htx' with parent 'audio-hdmi' already present!
[ 7.782931] 003: debugfs: Directory '30c10000.sai' with parent 'imx8mp-nau8822' already present!
TorizonCore with PREEMPT_RT 5.3.0-devel-202106+build.14 verdin-imx8mp-06848946 ttymxc2
I modified the kernel command line args with the TorizonCore Builder to get better latency (cpuidle.off=1, cpufreq.off=1): torizoncore-builder kernel set_custom_args “cpuidle.off=1” “cpufreq.off=1” (4.4. Linux — EC-Master 3.1 documentation)
I can see cpuidle and cpufreq are disabled, as the dont appear anymore in list when running ls /sys/devices/system/cpu/
The CPU-Temperatures are around ~50°C (cat /sys/class/thermal/thermal_zone0/temp).
Without the modification of the kernel arguements the container runs fine but the maximum latency is rather on the upper limit. I need to have a latency <100us because of Ethercat. With the modified image i get a maximum latency of ~70us, which would be fine (i could only run the rt-validation tests for around 30min, because of the reboot problem).
Do you have any idea why the system gets rebooted?
unfortunately there is no message before rebooting. I can reproduce the issue with a network speedtest, so it seems network related. You can use my speedtest-cli container: docker run -it wheeler1818/speedtest-cli. In 50% of the cases the session hangs (not the whole system) and the system gets rebooted after a few minutes:
Retrieving speedtest.net configuration...
Testing from UPC Schweiz ...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by HEIG-VD (Yverdon-Les-Bains) [75.64 km]: 32.131 ms
Testing download speed........................................................>
Normal Boot
CPU: Industrial temperature grade (-40C to 105C) at 48C
Reset cause: POR
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
BuildInfo:
- ATF 835a8f6
Fastboot: Normal
Normal Boot
Scanning mmc 2:1...
1182 bytes read in 8 ms (143.6 KiB/s)
4762 bytes read in 13 ms (357.4 KiB/s)
85718 bytes read in 19 ms (4.3 MiB/s)
73 bytes read in 13 ms (4.9 KiB/s)
1879 bytes read in 20 ms (90.8 KiB/s)
212 bytes read in 16 ms (12.7 KiB/s)
11629598 bytes read in 50 ms (221.8 MiB/s)
9170412 bytes read in 44 ms (198.8 MiB/s)
Starting kernel ...
[ 0.086332] 002: No BMan portals available!
[ 0.087076] 002: No QMan portals available!
[ 1.250934] 001: imx8-pcie-phy 32f00000.pcie-phy: failed to get imx pcie phy clock
[ 1.282401] 002: imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 1.282418] 002: imx_sec_dsim_drv 32e60000.mipi_dsi: Failed to attach bridge: 32e60000.mipi_dsi
[ 1.282423] 002: imx_sec_dsim_drv 32e60000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 1.339197] 002: failed to register cpuidle driver
[ 1.682478] 001: imx_sec_dsim_drv 32e60000.mipi_dsi: modalias failure on /soc@0/bus@32c00000/mipi_dsi@32e60000/port@1
[ 1.773235] 001: cpufreq-dt cpufreq-dt: failed register driver: -19
[ 2.840469] 002: imx6q-pcie 33800000.pcie: failed to initialize host
[ 2.840473] 002: imx6q-pcie 33800000.pcie: unable to add pcie port.
[ 9.954151] 001: nau8822 3-001a: Failed to issue reset: -6
I’m currently running some tests to try to reproduce your issue, so we can try to investigate better.
For now, I have two comments:
From your Serialoutput.txt we can see that there is no indication of a kernel failure
When I pulled the stress-test for the first time after installed the TorizonCore 5.3.0 with PreemptRT, I saw the same behavior: reboot without any indication on the serial output. I solved it by using a more capable power source.
So, my question is: what power source are you using? Could you try again with a more capable power source?
i’m using a 12V/2A power supply. I tried it with a 24V/4A. Unfortunately the behaviour is the same. When running the stress-test container the board gets rebooted after 15-60min. With the speedtest-cli container the reboot comes earlier, without any stress testing. Have you applied the kernel commandline parameters cpuidle.off=1 cpufreq.off=1 ? Could it be a watchdog, who is rebooting the system?
Before running both the stress-tests and the rt-tests, I launched a script the logs the docker stats in a file. With this, I can analyze for how long the test run. Here is the script:
# file: docker-logger.sh
# how to launch:
# nohup sh docker-logger.sh &
log_file=/home/torizon/docker-stats.log
sleep_time=2m
while :
do
echo "date $(date +%s)" >> $log_file
docker stats --no-stream >> $log_file
sleep $sleep_time
done
Test 1:
– Default kernel arguments (no cpufreq and cpuidle disabled)
– Result: executed for 43127 seconds (or 11h59)
many thanks for the detailed clarification. I have only one Verdin IMX8M Plus Quad module. We ordered more modules, they should arrive in 3 weeks. I report back when i tested it with another module.
i recieved a replacement module. Unfortunately i have the same behaviour. So i tried with a Dahlia carrierboard. The test is now running 3h and more. So it seems to be a hardware issue of the carrierboard not the cpu module itself. I will get in touch with the RMA department to get a replacement.
i tested it again with brand new Carrierboard, CPU Module and Image. Unfortunately i have the same behaviour.
Model: Toradex Verdin iMX8M Plus Quad 4GB Wi-Fi / BT IT V1.0D, Serial# 06965602
Carrier: Toradex Verdin Development Board V1.1A, Serial# 10807547
Image: torizon-core-docker-rt-verdin-imx8mp-Tezi_5.4.0-devel-202109+build.18: Download here
I have some more hints for reproducing:
The issue seems network related and only appears with the eqos (ethernet@30bf0000) driver. This is connector X25 on Verdin Development Board.
The issue does not appear with the fec (ethernet@30be0000) driver. This is connector X35 on Verdin Development Board. With an usb-to-ethernet adapter the issue does also not appear.
To which network connector did you connect the network cable, when you did the tests?
Can you please rerun the test, when you connect the network cable to connector X25 on Verdin Development Board. Please also verify that tcp port 5201 is open for iperf3.
I don’t know if these optimizations are necessary. The latency is not really better in the mesurements you did. But anyway i think the module should not reboot with these optimizations .
the link to the image was wrong. I replaced it with the official toradex image. You have to apply the kernel commandline by yourself. Or you can use the image from your previous tests.
You raised intriguing points. I really didn’t pay attention to which network interface I connected.
I’ll rerun the tests using each of them. If I get the same error, maybe you found a possible improvement point.
I don’t get the reason of this specific port… Could you explain, please?
About the latency, I agree with you: since the worst-case delay was the same for these tests, seems like that under the stress caused by the stress-test the response time isn’t enhanced by turning off cpufre and cpuidle.
But keep in mind that this kind of stuff does not necessarily have a linear behavior. Under a different kind of processing load, maybe applying these modifications can provide better results.
the stress test container is using iperf3 to generate network load. iperf3 uses tcp port 5201 for the connection to the server. So this port should be open otherwise no load is generated (it was blocked in my company ).
Yes under stress the latency is not really better. I found out, that under idle or low load the latency is slightly better. Our application will probably not use more than 25% cpu load, so i expect that the modifaction will improve the latency.
The stress test conditions are very unrelaistic for our application and in this case the problem would not be serious.
But the problem also happens with no other load than network load. For example when pulling a large docker image or running a speedtest (speedtest-cli) or it even could happen when downloading a OTA-Update. In this case i think the issue is serios.
Using the other network interface is also no an option for us, as we must use the fec-adapter for ethercat.
Several tests were carried out up to a point that the problem could not be reproduced anymore on recent nightly builds of TorizonCore. More than one module is currently running for more than 1 day without the rebooting problem.
I’m attaching here a quite recent nightly build of TorizonCore 5.5.0 with Preempt RT (build 465 from 22/11/2021), which is the same as one of the running modules currently in test: https://share.toradex.com/dt5srknygx174kj
Please run some tests on your side with it to see if the reboot issue keeps happening.
If you reproduce the rebooting issue, we will need a more deterministic test setup because we are not able to reproduce with this image (until now).
