Hello guys,
I’m getting a strange issue, I’m testing iMX8M Mini DualLite WB IT with carrier board Dahlia and DSI-to-HDMI adaptor.
When I flash the TozisonOS 5.7.2 with example containers, everything seems ok and the portainer interface appears on the HDMI display, but If I try to flash the 6.5.0 the display does not show anything, but the serial terminal seems to boot the torizoncore.
I tried to flashe torizon 6.5.0 using easyinstaller 5.7.3 and 6.5.0 with the same results.
Analysing both boot logs I saw that the 6.5.0 torizoncore image give me an error related to DSI and could this could be the problem? How can I solve this?
[ 2.740135] [drm:drm_bridge_attach] *ERROR* failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e10000 to encoder DSI-34: -517
Attached are the boot logs:
5.7.3, boots OK and shows HDMI OK
U-Boot SPL 2020.04-5.7.2+git.33bb8e968332 (Jan 01 1970 - 00:00:00 +0000)
DDRINFO: start DRAM init
DDRINFO: DRAM rate 3000MTS
DDRINFO:ddrphy calibration done
DDRINFO: ddrmix config done
Normal Boot
Trying to boot from MMC1
NOTICE: BL31: v2.2(release):toradex_imx_5.4.70_2.3.0-g2fa8c6349e
NOTICE: BL31: Built : 00:00:00, Jan 1 1970
U-Boot 2020.04-5.7.2+git.33bb8e968332 (Jan 01 1970 - 00:00:00 +0000)
CPU: i.MX8MMDL rev1.0 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 51C
Reset cause: POR
DRAM: 1 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1
Fail to setup video link
In: serial
Out: serial
Err: serial
Model: Toradex Verdin iMX8M Mini DualLite 1GB WB IT V1.1C, Serial# 14756371
Carrier: Toradex Dahlia V1.1D, Serial# 11287142
BuildInfo:
- ATF 2fa8c63
- U-Boot 2020.04-5.7.2+git.33bb8e968332
flash target is MMC:0
Net: eth0: ethernet@30be0000
Fastboot: Normal
Normal Boot
switch to partitions #0, OK
Scanning mmc 0:1...
Found U-Boot script /boot.scr
973 bytes read in 12 ms (79.1 KiB/s)
## Executing script at 47000000
4651 bytes read in 22 ms (206.1 KiB/s)
65327 bytes read in 29 ms (2.1 MiB/s)
47 bytes read in 24 ms (1000 Bytes/s)
Applying Overlay: verdin-imx8mm_lt8912_overlay.dtbo
1620 bytes read in 32 ms (48.8 KiB/s)
12197548 bytes read in 291 ms (40 MiB/s)
Uncompressed size: 30724608 = 0x1D4D200
9171554 bytes read in 226 ms (38.7 MiB/s)
## Flattened Device Tree blob at 44000000
Booting using the fdt blob at 0x44000000
Loading Device Tree to 000000007d6d8000, end 000000007d70afff ... OK
Modify /vpu_g1@38300000:status disabled
Modify /vpu_g2@38310000:status disabled
Modify /vpu_h1@38320000:status disabled
Delete node /cpus/cpu@2
Delete node /cpus/cpu@3
Update node /thermal-zones/cpu-thermal/cooling-maps/map0, cooling-device prop
Update node /pmu, interrupt-affinity prop
Starting kernel ...
[ 0.069499] No BMan portals available!
[ 0.069999] No QMan portals available!
[ 1.207398] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.215704] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517, retry 0
[ 1.591241] pca953x 3-0021: failed writing register
[ 2.834167] imx6q-pcie 33800000.pcie: failed to initialize host
[ 2.840100] imx6q-pcie 33800000.pcie: unable to add pcie port.
Starting version 244.5+
[ 7.043173] debugfs: Directory '30020000.sai' with parent 'imx8mm-nau8822' already present!
[ 8.042956] mcp25xxfd spi2.0: CRC read error: computed: 6c2a received: ffff - data: be 00 04 ff ff ff ff
[ 8.052985] mcp25xxfd spi2.0: CRC read of clock register resulted in a bad CRC mismatch - hw not found
[ 8.063932] mcp25xxfd spi2.0: Probe failed, err=84
TorizonCore 5.7.2+build.20 verdin-imx8mm-14756371 ttymxc0
verdin-imx8mm-14756371 login:
6.5.0, boots OK but HDMI shows nothing
U-Boot SPL 2022.04-6.5.0+git.28dc906f6107 (Jan 01 1970 - 00:00:00 +0000)
WDT: Started watchdog@30280000 with servicing (60s timeout)
NOTICE: BL31: v2.6(release):lf_v2.6-g3c1583ba0a
U-Boot 2022.04-6.5.0+git.28dc906f6107 (Jan 01 1970 - 00:00:00 +0000)
CPU: Industrial temperature grade (-40C to 105C) at 52C
Reset cause: POR
DRAM: 1 GiB
Core: 114 devices, 21 uclasses, devicetree: separate
In: serial
Out: serial
Err: serial
Model: Toradex 0060 Verdin iMX8M Mini DualLite 1GB WB IT V1.1C
Serial#: 14756371
Fastboot: Normal
Normal Boot
Scanning mmc 0:1...
973 bytes read in 1 ms (950.2 KiB/s)
## Executing script at 50280000
6659 bytes read in 2 ms (3.2 MiB/s)
66144 bytes read in 2 ms (31.5 MiB/s)
86 bytes read in 2 ms (42 KiB/s)
Applying Overlay: verdin-imx8mm_dsi-to-hdmi_overlay.dtbo
2317 bytes read in 2 ms (1.1 MiB/s)
Applying Overlay: verdin-imx8mm_spidev_overlay.dtbo
561 bytes read in 3 ms (182.6 KiB/s)
13423185 bytes read in 80 ms (160 MiB/s)
11575236 bytes read in 70 ms (157.7 MiB/s)
Uncompressing Kernel Image
## Flattened Device Tree blob at 50200000
Booting using the fdt blob at 0x50200000
Loading Device Tree to 000000007ded9000, end 000000007df0cfff ... OK
Starting kernel ...
[ 1.253625] pca953x 3-0021: failed writing register
[ 2.504430] regulator-dummy: Underflow of regulator enable count
[ 2.751882] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 2.760199] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
Starting version 250.5+
[ 9.530872] mcp251xfd spi2.0 (unnamed net_device) (uninitialized): Failed to detect MCP251xFD (osc=0xffffffff).
TorizonCore 6.5.0+build.8 verdin-imx8mm-14756371 -
