im trying to connect to my iMX8 remotely using FreeRdp. According to the wiki page:
it is applicable on iMX8.
I found the freerdp recipe and added the package through local.conf
IMAGE_INSTALL_append = " freerdp"
the Image is built correctly. but in Linux it seems only “xfreerdp” is available and it didnt work. Since the iMX8 image uses wayland display protocol, i guess the suitable freerdp tool for it should be “wlfreerdp” right?
is there a way to use the freerdp protocol on iMX8 ?
I also tried to apply the PACKAGECONFIG for wayland, but when I did this, I did not have a CLI for freerdp. However, you should still be able to use xfreerdp on the iMX8 in general, even with Wayland (makes use of xwayland). I think the CLI of the application recently changed and the documentation you mentioned is still the old one. Could you try the following:
