Hi
I am unable to get the board into recovery mode. I have shortened the pins as per the photo ( https://developer.toradex.com/knowledge-base/load-toradex-easy-installer#tab-apalis-imx8 ) but it won’t go into recovery.
I shorten the pins, turn power on, wait more than 6 seconds and let go. Every time it goes through normal boot up and shows the Portainer.io screen. The red reset LED will come on and after 4-5 seconds always turns off.
I have tried holding it for shorter amount of time (2-3 s), longer amount of time (20 seconds). I have power cycled the board several times (not shorting the pins) with everything disconnected. I have also tried with everything disconnected and trying to get into recovery.
Setup
DVI video connection
USB-RS232 connection (X29)
USB OTG (X50)
USB mouse and keyboard
Any ideas, what can I try?
Thank you
Peter
