I’m working on a project in which a cortex-A CPU in the imx8 sends data through SPI, waits a short while (~6µs) then recieves data again with an SPI transfer.
The Problem: As we tested the program under the realtime patched linux system,
we notice a big jitter between those two SPI transfers, where the 6µs is not held. instead a jitter up to 1.5 ms happen between the transfers.
we repeated the test on 2 different linux kernels and could reproduce the jitters.
The following pictures shows the chip select signal of the SPI (SPI1_CS).
the purple signal is a result of adding up the oscilloscope pictures over the test time.
first test environment: # Linux apalis-imx8 4.14.117-rt59-89455-g4ed9379-dirty #1 SMP PREEMPT RT
test time: ~2hours
[upload|SfNi7sj3zxiqGpaUdoz9+GvZLvY=]
second test environment:Linux apalis-imx8 4.14.159-rt70-3.0.3+gfff496c #1 SMP PREEMPT RT
test time: ~12 hours
I updated to BSP 3.0b4, but the SPI behaviour seem unfortunately just the same.
Kernel: Linux apalis-eval-imx8-man 4.14.170-rt74-3.0.4+gbaa6c24 #1 SMP PREEMPT RT
To check the jitter of each part of the test program, I used a gpio for each part.
all gpios are switched to high at the beginning of the test program, then one gpio is switched to low after each part is executed.
In addition I configured the nanosleep function to so that it make the thread sleep at absolute time.
This modification makes it more clear that the big jitter comes from the SPI transfer.
Being at Home-Office, I cannot do the measurement this week. I will try to reproduce the issue next week.
However you need to test your code without RT Kernel Patch and compare this to the kernel with Real-Time kernel Patch. We have not done any tests on iMX8QM, so I cannot provide any values. Using Linux OS there always will be a jitter even with Real-Time patch.
What is your application? What values for jitter do you expect?
our application is a real time critical measurement for motion control. I know we could do it on the Cortex-M side, but that would add additional development efforts for communication between Cortex-M and Cortex-A side.
I would expect to see a jitter that is roughly the same as the worst case latency from cyclictest (<<100µs). What we are seeing are jitters of > 400 µs, so I suspect we are not using the system correctly or the SPI driver isn’t RT-aware.
First tests with setting the “rt-flag” in spidev.c seem to show improvement, but we need to do long-term measurements to be sure.
Two more tips which can improve the latency seen on SPI:
Disable DMA. Setting up DMA, initiating transfer with it typically takes time and makes the worst case latency worse. The driver used on the i.MX 8QM is this: drivers/spi/spi-fsl-lpspi.c. If you recompile the kernel anyways you can just set fsl_lpspi->usedma to 0 always.
Second, the driver makes use of runtime power management. Runtime power management shuts down clocks when the peripheral is not in use. Clocks on i.MX 8QM are handled by a special controller, and therefor may take time to enable. Leaving clocks enabled always is probably the way to go when trying to achieve lowest latencies. As a hacky way, I think removing SET_RUNTIME_PM_OPS in the struct dev_pm_ops should do that.
Btw, you should be able to change the scheduling priority of the SPI message pump also by using user space tools. Kernel threads are in square brackets. You can use ps to find the pid of the message pump, and set its priority:
By commenting out the SET_RUNTIME_PM_OPS in the mentioned struct in spi driver, I get a kernel panic when i start the program with the spi communication.
