While sending 100 Bytes through SPI, a relatively big latency emerges after bursting 512bits (64Bytes) of data, then the SPI driver continue sending the rest bytes (36Bytes) as shown in picture:
How can increase the burst size (or how can i remove this latency)?
Oscilloscope:
SPI C code:
#define SPI_CLK_SPEED 20 * 1000000
#define SPI_BITS 8
#define SPI_DELAY 0
static const char *device = "/dev/spidev0.0";
struct spi_ioc_transfer tr;
int fd_spi;
uint8_t default_tx[100] ;
uint8_t default_rx[ARRAY_SIZE(default_tx)] = {0, };
void transfer(int fd,struct spi_ioc_transfer* tr, uint8_t const *tx, uint8_t const *rx, size_t len)
int ret;
tr->tx_buf = (unsigned long)tx;
tr->rx_buf = (unsigned long)rx;
tr->len = len;
ret = ioctl(fd, SPI_IOC_MESSAGE(1), tr);
if (ret < 1)
pabort("can't send spi message");
exit(1);
int SPI_init( const char *dev,struct spi_ioc_transfer *tr,uint32_t mode,uint8_t bits,uint32_t speed,uint16_t delay)
int spiFD,ret;
tr->delay_usecs = delay;
tr->speed_hz = speed;
tr->bits_per_word = bits;
if (mode & SPI_TX_QUAD)
tr->tx_nbits = 4;
else if (mode & SPI_TX_DUAL)
tr->tx_nbits = 2;
if (mode & SPI_RX_QUAD)
tr->rx_nbits = 4;
else if (mode & SPI_RX_DUAL)
tr->rx_nbits = 2;
if (!(mode & SPI_LOOP)) {
if (mode & (SPI_TX_QUAD | SPI_TX_DUAL))
tr->rx_buf = 0;
else if (mode & (SPI_RX_QUAD | SPI_RX_DUAL))
tr->tx_buf = 0;
spiFD = open(dev, O_RDWR);
if (spiFD < 0)
pabort("can't open device");
// spi mode
ret = ioctl(spiFD, SPI_IOC_WR_MODE32, &mode);
if (ret == -1)
pabort("can't set spi mode");
ret = ioctl(spiFD, SPI_IOC_RD_MODE32, &mode);
if (ret == -1)
pabort("can't get spi mode");
//bits per word
ret = ioctl(spiFD, SPI_IOC_WR_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't set bits per word");
ret = ioctl(spiFD, SPI_IOC_RD_BITS_PER_WORD, &bits);
if (ret == -1)
pabort("can't get bits per word");
// max speed hz
ret = ioctl(spiFD, SPI_IOC_WR_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't set max speed hz");
ret = ioctl(spiFD, SPI_IOC_RD_MAX_SPEED_HZ, &speed);
if (ret == -1)
pabort("can't get max speed hz");
printf("spi mode: 0x%x\n", mode);
printf("bits per word: %d\n", bits);
printf("max speed: %d Hz (%d KHz)\n", speed, speed/1000);
return (spiFD);
int main()
fd_spi = SPI_init(device,&tr,SPI_MODE,SPI_BITS,SPI_CLK_SPEED,SPI_DELAY);
fd_spi01 =
while(1)
usleep(200);
transfer(fd_spi,&tr, default_tx, default_rx, 100);
