How do I configure MIRACAST mode ?
- No device is found when we enable settings on Android.
Is any application necessary for it to work?
Hi @aviau ,
Can you please share with us more information about your setup? Which module and baseboard are you using?
According to this question on the NXP community, it seems that two years ago the Miracast wasn’t supported on NXP BSP, I’m searching internally if this is still the same.
Daniel Morais
Apalis Evaluation Board V1.1A + Apalis SOM V1.1C + Kynetics BSP Android 10
