Imx7d Wakeup from suspend
Hi all,
On my imx7d emm when I enter the command echo standby > /sys/power/state, i see that my device correctly enters standby mode.
However when I touch the touchscreen the device briefly resumes running, then reboots automatically.
Why would the touch screen be doing this? The touch IRQ is connected to GPIO6_IO22, the wakeup pin wakes the device up just fine and it behaves as expected.
How can I stop this unwanted resume from the touchscreen?
Hi @eoin_oc ,
Can you please provide more information about your environment? Are you using a custom carrier board? Which BSP are you using?
It’s strange that the touchscreen is waking up the system, can you please check what are the wake-up sources of your system? You can check it by running the command cat /sys/class/wakeup/*/name, this is the output for the standard image:
root@colibri-imx7-emmc:~# cat /sys/class/wakeup/*/name
30370000.snvs:snvs-rtc-lp
alarmtimer
gpio-keys
Please also check which GPIO is configured as wake-up, you can do this by running the command cat /sys/kernel/debug/gpio, the standard pin is the GPIO1_IO01 (SODIMM 45).
Daniel Morais
It turns out there was a line in my st1633.c touchscreen driver which enables it as a wakeup source. I removed this recompiled the Kernel, and it is behaving now
Perfect that you found a solution. Thanks for the feedback.
