sandy
1
Hello
I have probem to get working LCD interface with LCD Display(1280x800) using BSP 6.1.76(kirkstone Yocto).
I worked in u-boot, device tree and device tree overlays to bring up the LCD.
device-tree will imx7-colibri.dtsi will as below
&lcdif {
assigned-clocks = <&clks IMX7D_LCDIF_PIXEL_ROOT_SRC>;
assigned-clock-parents = <&clks IMX7D_PLL_VIDEO_POST_DIV>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lcdif_dat
&pinctrl_lcdif_ctrl>;
status = "disabled";
port {
lcdif_out: endpoint {
remote-endpoint = <&lcd_panel_in>;
In u-boot i changed the “vidargs” and “video mode” to my corresponding LCD resolutions and also changed the device tree overlay as same.
I am getting PCLK as 23.4MHz, how can I to change in into 60MHz
My LCD is RGB(18 bit) to LVDS converter from iMX7D som.
- Yocto kiskstone 6.1.76 Reference Multimedia Image
Help me to bring up the LCD,
Thank You.
Please refer to this article for details:
sandy
4
Hello, Thanks for your reply,
I have tried all those things that you have shared article,
changing the followings
- vidargs as
setenv vidargs video='mxsfb:1280x800M-18@30'
in u-boot while the board boots and as well as u-boot source.
- device tree arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi
&lcdif{
display = <&display0>;
lcd-supply = <®_3v3>;
display0: lcd-display {
bits-per-pixel = <18>;
bus-width = <18>;
display-timings {
native-mode = <&timing_wxga>;
timing_wxga: 1280x800 {
clock-frequency = <23702400>;
hactive = <1280>;
vactive = <800>;
hfront-porch = <70>;
hback-porch = <70>;
hsync-len = <20>;
vback-porch = <10>;
vfront-porch = <10>;
vsync-len = <3>;
de-active = <1>;
hsync-active = <1>;
vsync-active = <1>;
pixelclk-active = <1>;
- Device tree overlay display-vga-640x480_overlay.dtsi
panel-timing {
hactive = <1280>;
vactive = <800>;
hsync-len = <20>;
hback-porch = <70>;
vsync-len = <3>;
vback-porch = <10>;
hsync-active = <1>;
vsync-active = <1>;
I modified all the above mentioned changes as per the article.
and the result of fbset is
root@colibri-imx7-emmc-15145878:~# fbset
mode "1280x800-0"
# D: 0.00 MHz, H: 0.00 kHz, V: 0.00 Hz
geometry 1280 800 1280 800 32
timings 0 0 0 0 0 0 0
accel true
rgba 8/16,8/8,8/0,0/0
endmode
but I can’t get the LCD, only back light is working but can’t get anything on display.
also I can’t able to change the PCLK,
Thank you.
Hi @sandy ,
Can you please share the datasheet of the display?
